P1000 honda p1000 will only shift into 2 after sitting 6 yrs
helander14312
27
53
illinois
There was a code that was for a air sensor...I forgot to plug in the sensor on the air filter, otherwise no. There is not wiring going to the seatbelt, but i clipped it behind me for test purposes anyways. It had no effect. When it first was fired up a few months ago I had one that said a speed sensor, but that went away.
Reactions: ChadD
DRZRon1
DRZRon1
1,434
4,392
PA
Unless I’m wrong - they all have a seat belt switch unless it was previously jumped out/removed
Reactions: ChadD
DRZRon1
DRZRon1
1,434
4,392
PA
I could be wrong / lol - does it feel like it’s cutting out and in when driving ?
Reactions: ChadD
helander14312
27
53
illinois
If I am reading it right…
7 is coolant sensor
8 tp sensor (was fooling with when I was diag injectors and iac)
9 is iat, left unplugged by accident once
12 and 13 is fuel pump, was bad, now replaced
29 iac, was bad and replaced
64 is ign fuse, was blown when I got it and was replaced
67 front vs sensor?
Hello_Darkness
Hello_Darkness
666
2,678
Just to the right of nowhere
7 is coolant sensor
67 front vs sensor?
The front vehicle speed sensor is in the top of the front differential.
906UP
906UP
15,015
142,633
da Yoop
@Hello_Darkness just curious, is it possible the clutches are stuck?.....as in not releasing? I've seen it on old cars, trucks & tractors when they've sat for a long time, as in years. The disc would get stuck to the flywheel, usually took a few pulls with a tow strap with someone holding the clutch pedal down to break them loose. Thinking back it's a wonder we didn't kill ourselves 🤣
  • Haha
Reactions: Smitty335 and ChadD
helander14312
27
53
illinois
Gonna call the dealer in the morning on the sensor. Clutches are releasing, Atleast seem to be, does good in first with takeoff, reverse, and when I can get it in second
Reactions: ChadD
Hello_Darkness
Hello_Darkness
666
2,678
If the speed sensor doesn't read, the unit won't shift.
Similarly if you have all 4 wheels off the ground and put the unit in gear with only 2wd engaged it won't shift. It needs to see all 4 wheels spinning to shift, we'll atleast the ring inside the front diff anyway.
Hello_Darkness
Hello_Darkness
666
2,678
Usually on the 1000 engine, if the clutches are stuck together it would be very difficult to move the shift lever. The unit would creep very badly as well. If anything, it might shift just very harsh and maybe get stuck altogether due to the dual clutch setup.
Reactions: ChadD and 906UP
helander14312
27
53
illinois
It takes finessing to get it to shift when it does, gotta rev and get off the throttle while hitting the paddles. Worth a shot! Hopefully it’s in stock. Got white fenders arriving tomorrow anyways the front will be exposed
Reactions: ChadD
Mark in Northern Iowa
501
2,217
Floyd County, Iowa
kramnella.wixsite.com
7 is coolant sensor
67 front vs sensor?
Looks like you have most of them about fixed.
If you haven't already found it, clearing the codes is on page 4-9 in the Service Manual.
1739507515503
When complete, or before, clear the codes.
Then if something else goes wrong later, you won't be chasing the old codes.
Have a good day
