![Travis R](/data/avatars/m/44/44969.jpg?1641969658)
Yep, I now think it’s the shift motor also. I will replace.the master indicated to take shift motor off and inspect/clean/replace
agree - still at step 1, inspect, clean, etc. - it could be a bad connector \wire for all we knowYou can try by cleaning it first.Then Honda shift motor imo.
Try it if he’s not planning to take it back.Good morning from Southeast Louisiana! I got a quick question.
Should I buy an aftermarket shift motor or Honda the OEM?
My cousin has a new aftermarket shift motor for his 2013 Honda Rancher 420 that’s never been used and I thought about buying it from him.
What do y’all recommend?
Thank you and have a blessed day!
its basically a mini DC motor similar to a car starter, no bend-ix, direct drive - flop polarity to drive it forward\reverse to switch gears, so it has brushes inside for the commutator - it could just be glazed over and dirty - who knows unless you look - I fixed my buddies P500, the shift motor the magnets cracked inside and came loose and would lock up the rotor, bought the non honda shift motor and put in and al was fine - we did go after connections, wiring first then were just looking to clean itagree - still at step 1, inspect, clean, etc. - it could be a bad connector \wire for all we know
honestly I have bought both - the non-ronda for a P500 and a Honda OEM for a P1000 - they both looked the same and both worked so who knows
who has one of those just lying around?🤣new aftermarket shift motor that my cousin had laying around.
It was for his 2013 Rancher 420 lolwho has one of those just lying around?🤣
geniusIt was for his 2013 Rancher 420 lol
glad u got it fixed. now get that thing snorkled before u have serious problems. again u do have a 16'.It was for his 2013 Rancher 420 lol
it’s like wheel brake cylinders on a Chevy - same cylinder used from the 50’s and up - if it ain’t broke - don’t fix itI have to give this the WOW factor for the fact the shift motor is so standard for different models.Same wiring ????
