P700m4 Cold start
Honda317
31
32
Oshkosh
just bought a used pioneer 700 2014 in Wisconsin it is starting to get cold it seems to start hard even though it is hooked up to a battery tender any suggestions or is this just normal.
Welcome to the forum! Is it the original battery? And do you mean that the engine cranks sluggish or that it just takes a while for it to fire. Because when I had my 700 in the mountains and snow, it would crank several times when it was cold. But it would fire right off once it was warmed up no mater the temperature.
Reactions: swsebek and Mudwing
Mudwing
Mudwing
36,959
306,672
The Mud holes
At start up, mine cranks for about five seconds and then starts. Test the battery if it seems weak.
Reactions: swsebek
Honda317
31
32
Oshkosh
I believe it is original battery and takes awhile before it fires up
Reactions: Mudwing
swsebek
swsebek
2,854
5,835
pa
@Honda317
I don't know your miles, but if it were me. I would get a new air cleaner, change out the spark plug, check the valves. Oil and filter change. That way you know all that is good to go. But mine will sometimes crank 8 times before it starts when it's cold out.
jwfirebird
jwfirebird
927
1,446
western ny
pretty much all atvs and utvs after mid 2000s have a lean tune for emissions and fuel efficiency. that will make them start hard in the cold, unless you do some sort of ejk. i did that on my can am for heat, lean tunes cause excess heat too, bigger jets in the prairie too also made them way easier to start in the winter
allgm1
allgm1
1,049
1,484
New Hampshire
Its common and I thing worsened by a tired stock battery. Mine cranks more than I'd like when cold starting but its just the nature of the beast. I put a car size battery in it just so I would know it has sufficient cold cranking amps especially after sitting in the shed at below freezing temps for a few weeks before I need it.
