pct
Lost in the hills
Well guys here we go no to good with a camera but first off is the front doors and bumper need to come off then pull the push pins out and remove the wheel flairs then you look under the front wheel ther are 4 phillips screws that hold the head light to the plastic then a 10mm bolt that holds the light in place
sorry for the bad pics but you can get the idea
a better pic
Now under the hood remove the battery and all the wiring take your time with the clips ( with 20+years doing auto body repair it helped on the removal of the plastics) it is not hard just take your time the only thing that needs uplugged is the headlights remove all the bolts and the clamp on the hose that goes to the air cleaner when removing the grill comes off with the fender assy and the headlights will stay on the bike
handle it with care so you don't break it there are 4 phillips screws that hold it to the fenders
after removing the grill look on the bottom of the frender assy there are 2 t nuts that must be removed and the clips that hold the relays
reinstall them in your new plastic and do everything in reverse it is not a bad job it would help if you had a buddy there to lend a hand if you have ant questions just ask
hope this helps
Paul
a better pic
hope this helps
Paul
