P700 Condensation in cargo trailer
  • Thread starter Bulldog-in-a-Pioneer700
  • Start date
15
39
Bellefonte, PA
Hi everyone, I'm new to the site as of October 2020, and appreciate your insight. I keep my 2021 Pioneer 700-2 inside an enclosed cargo trailer. I have found the environment upon reopening to be damp and at times even water droplets are present on my ride, tools etc. Any suggestions?
Mopower58
Mopower58
CST is the Best!
79,606
707,292
Crystal Springs,Ms.
Not sure how large they make them but have you considered desiccant packs or maybe rice? Welcome from Mississippi.
Reactions: ChadD
Vikes79
Vikes79
SKOL!
11,704
113,558
South Dakota
  2. Talon X4 LV
It’s more than likely from your machine it’s self.
your trailer is like a little green house...the moisture on the tires / machine is melting and evaporating during the day.
if you have a roof vent or window on your trailer all you need to do is open them.
TripleB
TripleB
15,184
135,504
Caryville, Tennessee
I use Damp Rid in a unheated mobile home that I use for storage only. Stuff would start getting mold on it until I started using that stuff. Works great.
Reactions: Mopower58 and ChadD
mj1angier
mj1angier
87
276
53
NC
Got to go one of two ways- vent it or seal it. The air needs to move in and out so not to have big temp changes. Or seal it tight and get the moisture out. These work good for that https://www.lowes.com/pd/DampRid-64-oz-Unscented-Bucket-Moisture-Absorber/50449432
But also don't load it up till it has cooled off. I ran into this with my generator box at our cabin. I would just put it up when leaving. Started to get a lot of moisture because motor was still hot. Now I let it set a hour or more before we leave.
Headhunterf100
Headhunterf100
60
106
Virginia
  2. Do not currently own
I rented a storage unit once and the lady highly suggested we put a open bag grilling charcoal in the corner and replace every 3-4 months. I being me didnt do it and cannot say whether it would help here or not. Maybe worth a shot though.
Vikes79
Vikes79
SKOL!
11,704
113,558
South Dakota
  2. Talon X4 LV
I like these as they can be opened and closed. These are for the side walls.
a similar version exists for the roof.
15
39
Bellefonte, PA
Thanks for the info, Vikes79. I'll check into these.
178,293
Like Vikes said, those side vents should do it. My enclosed came with them, one high on drivers side and one low on passenger side. They also serve the purpose of releasing built up gas fumes. That's good enough for cargo but also added a roof vent for when I'm in there.
