COPS overheat kit , from what and how its made , premature engine wear vs Correct Ways of solving overheating issues on P1000.
I try to concise and summarize my research on the overheat issue that everyone eventually will have once push extremely your p1000 on a trail or using track systems on warm Spring days.
I'll start with first myth that COPS is partnered with thermostat company which modify high flow thermostat , I think Dezrik Parks always makes comments on this subject about that its "press cut".
One of the customers of COPS shared with me his overheat kit thermo pics. Its heavily "modified" with file and sander and not a clean job as you can see, pointed with red arrows.
I spoke with MOTORAD USA who makes most of thermo for major retailers and they found only on 44 mm with offset that would fit honda , but its 180 F not lower.
I'm listing two examples of Autozone and Napa thermostats that are the same but labeled differently.
They will be good for light modification using sander and fit since they have offset already.
Please read article and it will explain to every small detail that lowering thermostat temps will fail your engine faster unless you racing and dont care about engine longevity.
Link - Low Temp Thermostats: What’s the Advantage?
Solution is combination of the following depending on how hard and how high altitude you ride :
- Tune which will change temp range on/off for a radiator fan
- Spal or similar high flow fans
- Bigger surface radiator
- Davies Craig Digital Thermatic Fan Switch Kit - Davies Craig DC-0444 Davies Craig Digital Thermatic Fan Switch Kits | Summit Racing
- Manual fan switch ( not optimal )
- Adding heater core will act as second smaller radiator
- If you know another way please suggest.
