P1000 Cover for shifter holes
popeye
popeye
3,275
14,644
kapowsin, Wa
It came in the mail yesterday, thanks again. Looks very professional D5e34992432949b02a6ffcd5afe7f946
HivoltageHonda
HivoltageHonda
374
367
Hernando, MS
How much is shifter cover? I guess I could paint it black ?
Montana
800
322
The shfter covers are $75 with check or $78 with Paypal. If you are going to paint it let me know I won’t buff it but will do a light sand for you for paint adhesion
Montana
800
322
Tony. I shipped to you today
Thanks Larry
I used a piece of black foam I had laying around the shop. Cut it down to an inch thick, cut slots in it for the lever to slide through. Used some contact cement to attach it to the back side of the dash. Stops all the hot air that was coming through.
Has that slot worn any and maybe become looser, maybe letting a little hot air through in the year plus that it’s been on there? What density of foam are you talking about? Thanks
BigOL3
BigOL3
2,997
8,920
What I want to know is how do you go about gluing it to the BACK side of the dash. I could hardly get my hand in there, much less get a sticky piece of foam lined up straight.
Reactions: Montecresto
Montana
800
322
Montana
800
322
Mark. I shipped your cover Monday
Thanks Larry
HivoltageHonda
HivoltageHonda
374
367
Hernando, MS
So this will stop the heat coming through in the summer and the cold in the winter?
It does a really good job on both. I have had my now coming up on the second summer and one winter and I really like it.
Reactions: HivoltageHonda
zmnypit
zmnypit
203
270
alabama
Do you have an answer/video on the installation?
If you have a radio or switch panel you could access it easily. I've got some rubber I plan on mounting it behind the dash on both levers one of these days.
BigOL3
BigOL3
2,997
8,920
I found it very tight just getting my hand to the point of where the shift lever is located, much less attaching rubber with glue and aligning correctly.
A
APEXHYDRO
asotin wa
This seems to work very well. No holes to drill. I used the existing bolt holes and converted to studs. I will see what more will cost I paid $125.00 with computer time. I think a duplicate will be $75. I do have more rubber I will donate
hello i am new to the site. i just purchased a 2017 1000 le 3 passenger/ with roof windshield and back , all factory products. i really like the over operation of my machine. the one issue is the heat - hot air coming from the shifter holes. i just found the thread that covers that. the biggest issue is the tremendous amount of heat being generated from behind the seat. i have had the Polaris 900 with the factory deluxe cab for years and just decided to upgrade to the 1000 pioneer over the new ranger 1000 . i did not expect the engine heat to be so poorly managed or contained. if anyone has figured this out i would really appreciate some help
thank you
ttechnology
ttechnology
78
376
53
Seattle
Montana - Do you have any LE covers available?
Thanks, Scott
