Crystal Beast
115,707
Best, most helpful response yet. Tried pushing little tab with screwdriver but still can’t get to release. One response said to just pull it off?!
When you “pry up” the tab with the screwdriver, (pull might be confusing) while u are prying the tab up, you have to finagle with your fingers and pull on both ends. there is a 3 ribbed rubber gasket that seals it really good from moaisture and can be a sticky bugger to get get the 2 pieces apart. keep working at it and be patient, u will eventually get it.
this will help if the plug in post #31 is what your trying to do?
J80
J80
36,867
362,200
WNC
2018 pioneer700-4. Power steering light is on and no power steering. Went to check fuse and don’t know how to get cover off!? Also, manual says go to dealer to replace fuse- really?
Admin note: Jump to answer --> Crystal Beast
Unfortunately that year in a 700-4 had some major recalls for letting to much Dust in and engine heat creating swamp ass and there were a few more I can’t recall. I’d probably trade it in for a whisper quiet krx if I was you.
NewHere2
NewHere2
Village Idiot In Training
41,894
345,165
High Plains of SD
Sorry Sir, tried to help
That’s how my 2018 700-4D is set up. If you get to rough with that release tab, and it breaks off, you can always put a zip tie around the box and cover.
