P500 Curved LED 30" light bar
sideXsideCity
sideXsideCity
So Wide Open product (jmatv.com) has joined the show as a sponsor and outfitted our 2015 500 with this 30" CURVED (a straight 30" would not fit) LED.
And this lights up the night!!
Super clean install with their harness/fuse/relay/on-off switch.
WP 20150908 012 WP 20150908 010 WP 20150908 009 WP 20150908 011 WP 20150908 013
Reactions: Hondalife
266,484
I beg to differ, a straight 30" LED light bar will fit a P500,
20150818 195459 zpslbkhflfc
20150819 174626 zpsob4scbcj
But you can't go wrong with either one really.
266,484
yes the inside mount only for curved but you could mount a 72" above the roof line HA!!
Mine is mounted to the roll bar front cross member with clamps exactly like yours, it is not mounted to the roof, it is mounted through the roof to the same top front ROPS cross member as you have photographed above.
bobbyhill
bobbyhill
Junior Moderator
1,271
952
Smithfield, VA
72 inch light bar on a 50 inch wide SXS? not with standard mounts you would have to fabricate.
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
Whats the part number on that exactly how i want to mount mine under the roof lol ill order one now
Reactions: sideXsideCity
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
Perfect as soon as i get permission or forgiveness from the wifey ill be calling
CBC89
CBC89
66
73
How much is this setup? where did you get these mounts?
