Desperately in need of help this Easter
Michigander
Michigander
90
174
I am in London KY right now and need a sub transmission drain plug. I cant figure out what thread pitch it is in order to get a bolt or drain plug to get me back going. The closest i have found is a 12-1.75 but it stops after a couple turns.
If i was home id iust order a new one through my dealership, but im from Northern Michigan, and came here for a vacation with the buggy. We are supposed to be riding wildcat offroad and then down into Windrock.
Id be willing to be taken advantage of at this point so i dont spoil everyone's fun.
Anyone able to get me one in the next couple of days, or know what thread pitch will work. Im willing to drive a few hours if need be.
Was humiliated that a Polaris had to pull me out of the park yesterday.
Once the oil ran out i got the oil warning light and it shut off and acted like its in nuetral. Will i be able to get it goinv once i get a plug and fluid?
20180331 172637
Michigander
Michigander
90
174
We tried every single one that Autozone and Advanced auto parts had...also went to a Lowes and Ace hardware with no luck
Michigander
Michigander
90
174
Strange when i go online it says the sub transmission size is a M12x1.5, i can say that a 12x1.75 is so close its scary
O2bsmitty
O2bsmitty
298
659
Illinois
Is it a possibility that the dealer cross threaded or stripped the threads that's why you can't find a match?
Reactions: sharp
66,873
You sure SUB TRANSMISSION? There is 3 bolts. Its the frontest one and it enters from the side of the case not straight down like the other 2?
BECAUSE.... Asking because the other 2 plugs are 12mm.
Reactions: Michigander
Michigander
Michigander
90
174
I better double check real quick
66,873
I may be wrong on side entry vs down.
But.. I know the front drain, (Sub trans), is a bigger, the oil pan and oil tank are the same size.
Sub trans is 14x1.5
Oil pan/tank is 12x1.5
According to info I have found.
Imag1809 png
It actually sounds like you lost engine oil because you would not get a oil warning light if you lost your sub transmission oil.
E
elkguide
3,377
7,964
Vermont
Engine oil for sure if the low oil pressure light came on.
Choogsbro
Choogsbro
CEO of Monkey Business
8,144
52,659
Monticello, Ky
Were you there for the rock crawlers ? How was it ? How did Mark Mathis do ? I know him.
Reactions: Chooglin
Eltobgi
Eltobgi
4,599
15,186
North Dakota
@Michigander can you verify which by checking the sub transmission oil level and the engine oil levelo_O
