P1000 Diff lock indicator
K
Kdogkan
Fl.
When I'm in turf mode and vehicle is placed in park, indicator switches to 2wd lock. When moved out of park, it goes back to unlocked. Is this normal??? Pics are in park and neutral. Thanks.
Image Image
270,888
Yes that is normal, it only detects if it is locked or not while in motion. Static it can't tell the difference.
Reactions: KissPV
K
Kdogkan
Fl.
Thanks Jackal. I greatly appreciate it. This forum is more informative than the dealer.
Reactions: KissPV and JACKAL
rmk700
Looks like your due for an oil change too.
Reactions: Kdogkan
K
Kdogkan
Fl.
Lol, yes it just came on last night.
View attachment 13752 View attachment 13754
Mine used to do that. I adjusted the cables under the driver side rear seat and it fixed it.
K
Kdogkan
Fl.
That sounds like a very good possibility for mine. The light was flickering last night when my son took it out. I'll start with that adjustment. Thanks Joey.
Reactions: KissPV and joeymt33
walexa07
walexa07
396
380
Louisiana
Looks like you need to add some gasoline, lol.
Waylan
Reactions: Kdogkan
I need the same adjustment! Would you pls point the way?
If you have a 5 seater, it's under the driver side floor. There is a panel that can be removed to access the metal box that holds the adjustment mechanism.
I'm not totally sure on the 3 seater, you may have to tilt the bed.
I'll dig around for some pics.
