P1000 Diff oils
Tundra20
Tundra20
316
812
Arkansas
I know this has been talked about but doing first service on diffs is lucus oil 85/90 good or should i stick with honda gear oil my local dealer did not have any said they didn’t know wen they were getting any so this is why I started shopping for another brand i know most of oils r about the same
Thoughts and suggestions appreciated
Dirtstiffs-1000
Dirtstiffs-1000
1,565
5,708
hondasxs.com
Download
I use this on everything I run.
Tundra20
Tundra20
316
812
Arkansas
Thx i had read somewhere lots of folks wer going to 75/140 cause of nosiey diffs I really haven’t noticed mine being to badd but i know mobile 1 is good
Thx again
Dirtstiffs-1000
Dirtstiffs-1000
1,565
5,708
hondasxs.com
Thx again
I don't have any noise issues.
It's great oil because the viscosity range handles a wide range of temperature and it doesn't breakdown. My results have been great.
Reactions: Tundra20
Tundra20
Tundra20
316
812
Arkansas
Ran lucus in some other stuff ive had thru the yrs always been good but i will for sure go to 75/140 will stop Tomorrow and get either lucus or mobile 1
duramaxman05
71
160
Perryville
I put lucas 75w140 synthetic in the differentials and it did make it a little quieter. 1qt does both the front and rear unless you have a limited which requires a little more.
Reactions: Tundra20
E
Ericthered
Eric The Red
271
522
Sparks, NV
I used the 75w140 synthetic in the transfer case under passenger seat. DID NOT WORK. Shifting became hard with first ever grinding noise. And shifter itself was hard to move. Afraid I was going to break/bend something inside. Anyway I had ZERO miles on it and changed it back to Honda lube. Now it works great with no grinding.
Reactions: duramaxman05
Tundra20
Tundra20
316
812
Arkansas
8B126F1F 9882 4025 BE29 779E6FCF3784
Got the diffs changed
oil was not dirty at all but went with mobil 1 75/140
