The headlights on Talon are pretty dim and maybe that's because they're LED and directional. I've been told a few times that they are hard to see when coming up on people. So I generally only use the high beam setting.
I was going to add a small 30W LED bar in the middle. Since I don't even use the low beams, I was thinking of just using the existing light switch.
Here's my plan
High beams always on when switch is in Low or High.
When I select the Low setting, high beams on factory stay on and the new 30 W led bar is on. (switch w/o relay should be able to handle this low current)
When selecting High, only factory high beams on and LED light bar off
this is how I think I should be able to do it
Can I just cut the white wire (for low beams) and take the end coming from plug and use that to drive the LED light bar? (of course I'd have to tap into green for ground/common.)
I see from the wiring schematic there there are diodes between the high and low beams.
Has anyone else done anything like this and know this will work before I cut the wire.
Here's my plan
