What is the dipstick under front seat? Mine isn't showing any fluid on the dipstick.
J Jasonpaul New Member May 31, 2019 3 3 3 Oromocto, NB, Canada Ownership 1000-5 Jun 5, 2020 #1 What is the dipstick under front seat? Mine isn't showing any fluid on the dipstick. Reactions: Isaiah
Russ989 Land of the free because of the Brave! 🇺🇸 Lifetime Member Supporting Member Club Contributor Dec 18, 2017 22,642 147,257 113 Missouri Ownership 1000-5 Jun 5, 2020 #2 Jasonpaul said: What is the dipstick under front seat? Mine isn't showing any fluid on the dipstick. Click to expand... It’s your sub-transmission, this should be what you’re looking at. Reactions: TripleB, Isaiah and CumminsPusher
J Jasonpaul New Member May 31, 2019 3 3 3 Oromocto, NB, Canada Ownership 1000-5 Jun 5, 2020 #3 Yep that's it. Reactions: Isaiah
J Jasonpaul New Member May 31, 2019 3 3 3 Oromocto, NB, Canada Ownership 1000-5 Jun 5, 2020 #4 What type of fluid does it hold? Should it be not reading on dipstick when engine is cold? Reactions: Isaiah
Ohio4x4 I brought the dishwasher Lifetime Member Aug 23, 2018 1,528 15,413 113 Ohio Ownership 1000-3 Jun 5, 2020 #5 Jasonpaul said: What type of fluid does it hold? Should it be not reading on dipstick when engine is cold? Click to expand... 10w30 honda gn4 is what I use in both my engine and sub trans. It should be on the dipstick. Reactions: TripleB and Isaiah
Major0887 Member Dec 2, 2018 30 60 18 Arizona Ownership 1000-3 Jun 5, 2020 #6 This should help Reactions: TripleB and Isaiah
t-bear Active Member Nov 11, 2019 93 112 33 NE OK Ownership 1000-5 Jun 8, 2020 #7 Oooof! You should be adding oil if it does not show! ETA - Check oil when cold with dipstick NOT screwed in, just sitting there. Yes it is your transmission oil. Yes it is the same as your motor oil = Honda GN4 10W-30 Motorcycle Oil - Gallon Last edited: Jun 8, 2020
JimmyA Well-Known Member Oct 8, 2017 1,644 5,504 113 Northeast texas Ownership 700-4 Jun 8, 2020 #8 Jasonpaul said: What is the dipstick under front seat? Mine isn't showing any fluid on the dipstick. Click to expand... Just wondering, did you get a owners manual when you purchased the pioneer?
t-bear Active Member Nov 11, 2019 93 112 33 NE OK Ownership 1000-5 Jun 8, 2020 #9 Glove box. Some have found it underneath rt front seat. Pull latchat middle of seat. But take our advice. Sub trans is dangerously low!
