P1000 DIY headlights
63,410
Darn. I was hoping the LOW stayed ON when switched to HI. But nope.
So.. I dont have a easy solution.
Diodes will have to be used. It will be a PITA to wire up.
Reactions: Isaiah and BWAF
evildoctor
evildoctor
61
94
NC
no worries, I was hoping it was something I missed but I thought I tried it. Anyways, it isn't a big deal b/c I have other led light bars mounted if I ever needed more lights. Thanks for your suggestion anyway...
Toyhauler33
Toyhauler33
Mid Ga
What about using a relay instead of diodes? Something similar to a HID relay harness maybe?
7,135
27,098
Are you guys wanting both fixtures to light on high?
Floods on low and spots and floods on high?
evildoctor
evildoctor
61
94
NC
Not sure if a relay will work. A relay is basically a switch but diodes is suppose to allow flow one direction similar to a check valve.
evildoctor
evildoctor
61
94
NC
Ok...after doing a little more research, I stand to be corrected. I believe a relay may be what I need although I also think a diode will work as well. Here's a video I found recently explaining how a relay(relays) are used in a "low and high beam" configuration. Not sure if this link will work but here it is.......
Reactions: Pilot2016
63,410
Ya, if you want to re-wire and re-design the whole switch/OEM relay system.
For me. I would want to retain the OEM switch/system.
Low = 1 cube on Flood
HI = both cubs on Flood + spot
evildoctor
evildoctor
61
94
NC
I think I'm gonna try the diode route first. on my previous diagram I drew up, I think all I have to do is add a diode on the 2nd wire running back to led light pod #1 from the high beam wire....so that when I turn on low beam it will prevent power going back to led light pod #2.
Reactions: Isaiah
319,555
I liked those in Talon, look good in Pioneer. Nice job. Do they vibrate at all.
evildoctor
evildoctor
61
94
NC
A little update....
So I try and do a little color match.
20200314 111650
20200314 111738
20200314 111745
