P700 Door rattle
Harman24630
Harman24630
283
493
Tazewell Va
Back doors have plenty of adjustment on the rubber stopperand don't rattle at all but the front stoppers are almost screwed all the way out and doors rattle like crazy. Does Honda or any aftermarket company make longer stoppers?
Harman24630
Harman24630
283
493
Tazewell Va
Forgot to mention this is when they are double latched
I cut a small piece of heater hose and pressed it over the stopper to extend it. I don't have a picture of that because I sold the vehicle. Here is an example:
28dc41b934d3876248ea8b450789bafb
L
longsidelandry
22
Delcambre, LA
Also, put some electrical tape around the latches, that helps big time! Just keep a roll in the bike for when they wear through. I'm going to try spraying mine with plasti-dip to see if it lasts longer.
Sent from my SM-G900V using Tapatalk
Harman24630
Harman24630
283
493
Tazewell Va
The heater hose trick worked wonders... Before that I had seen on here about the tape trick which lead me to think about splitting a piece of silicon tubing and clipping it around the bar part similar to how some strikers are done in trucks. But I had the heater hose on hand still want to try some tubing cause the heater hose can b knocked off if I rub it getting in and out.
Reactions: longsidelandry
