Is there enough room you could use a high-pressure gas strut?Has anyone replaced the junk door straps on the honda hard cab . My drivers door strap tore loose, its really a bad design
I doubled up black tie down strap same length.Has anyone replaced the junk door straps on the honda hard cab . My drivers door strap tore loose, its really a bad design
No but that would be awesomeIs there enough room you could use a high-pressure gas strut?
Ok here is what I came up with, they are mini rubber bungies That you can see I trimmed up and I have some 1/16 stainless cable that I will make up that will be an 1" or 2 longer to work as a stop to prevent over travel.View attachment 30885 View attachment 30886 View attachment 30887 View attachment 30887
watching... curious to see this installed...Ok here is what I came up with, they are mini rubber bungies That you can see I trimmed up and I have some 1/16 stainless cable that I will make up that will be an 1" or 2 longer to work as a stop to prevent over travel.View attachment 30885 View attachment 30886 View attachment 30887 View attachment 30887
I was hoping that would could do it but you're right with a strap it would release some tension and do the trick probablyWell here is the installed bungee, It will need the extra cable as a stop. It stretches way to far View attachment 31101
