P1000 Dual battery pic
Rubin
Rubin
45
170
Canada
This is an Excellent example of what all side by sides need. EA8331B4 1605 48B5 AF84 B128400C99BE
64,288
Looks good.
But what's the reason for the 2, 100A beakers to the isolator?
I understand the thought of "peice of mind". But realize if it shorts. Those 100A breaker won't stop that small ground wire from frying off. Assuming that's why you have them.
Just a thought.
What you have will work great.
Reactions: hurld and JenElio
Rubin
Rubin
45
170
Canada
This is just an outline of how to do a dual battery setup. Some people have to see it to understand .With this illustration and a bit more homework On how to make a fuse relay bord anyone could have a kickass Dual battery system that you can control with the flip of a switch.I only have a 200 amp fuse off my secondary battery going to a solenoid that I can turn on and off with a switch.F57CF424 E6D7 4DFA ADB6 BE264F416A0D My secondary battery is under my seat.
