P1000 Dual battery question - yes, another one...
CWhitmarsh
31
96
Port Angeles, WA
Good evening. I'm new to the forum and about to be a new owner of a Honda Pioneer 1000-5. I've seen a lot of talk about dual batteries for these machines and I've found it intriguing. The question I have is this: If I don't plan to put any electronic accessories on for quite a while, should I go forward with installing a second battery without any other accessories? If I do, do I need to add in the solenoid and extra fuse block for future accessories? Or do I just do that part in later when I start adding things?
Thanks for your input (Sorry for yet another question about dual batteries).
Chris
TripleB
TripleB
15,618
140,491
Caryville, Tennessee
Chris
I wouldn't worry about a 2nd battery with no accessories. If u add a winch, u could go ahead and do the 2nd battery and True AM isolator. Then when u wanted to add accessories u could just add your fuse block and switches.
Chevy412SP
Chevy412SP
102
126
Western New York
The whole reason for adding a second battery is because when you have accessories and start to draw additional power from the battery it starts to affect the operation of the transmission cause problems and slippage. If your not adding ANY accessories right now, then you don’t have to worry about the second battery until you start adding those accessories.
Wellzy
Wellzy
269
900
SW Wisconsin
I just received a second battery and True isolator kit. I have no accessories to add yet, but I will eventually add a stereo. I'm putting the battery in now, but it will not have anything connected to it yet. Is this dumb of me? I have a fuse block that I will wire in after I get my Stinger, but I am not going to run a winch ever. Does this make sense or did I just waste $ and time?
Wellzy
Wellzy
269
900
SW Wisconsin
I could see that being just fine, as whatever I install to the fuse block will have a switch. Then I could turn on anything without using the key. I have a question though if you don't mind. Some people install fuses between the Aux battery and the fuse block, maybe even before the Stinger. I don't know much about where they should be placed, but do you have any large fuses between your Aux battery and the fuse block?
IMG 8456 IMG E8455
