Dual battery removal
dukeANhammer
dukeANhammer
60
147
So i have the dual battery setup and was wondering if the extra battery is removed, will the machine still start? The starter relay is buzzing?
Reactions: ChadD and Backwoods
5,413
24,849
11.8 is pretty much dead as far as I know. How long was it sitting? You might have a parasitic draw necessitating a trickle charger between uses.
OIP
dukeANhammer
dukeANhammer
60
147
How old are they and was the buggy sitting for an extended period? Unless both are 'really' old, I find it hard to believe that both died together.
It’s a 2019, i put the dual battery on it about 1 year ago. It might get run once a month but is garage kept with a battery tender. The secondary battery is a Amazon special, gel battery. I find it hard to believe myself, I’ve noticed a glowing led on part of the dual battery kit, i believe i ordered from this site.
Reactions: Backwoods
5,413
24,849
If it's a True isolator, that blue glowing LED tells you the primary battery is fully charged and the isolator has connected the second battery to the charging circuit.
