This is how I laid mine out.FWIW I have two length wise strips of etrack in the floor of my enclosed trailer and a row at 2’ and another at 5’ on the walls of my enclosed trailer.
You can never have too much of the stuff and if you do it right your trailer will be infinitely useful.
I think I have something like 90’ of etrack in my 7x14 enclosed trailer. It cost some coin, but was worth it as the stuff makes moving and securing items a breeze.
I did not tailor it for my p1k5, but to do everything I need.
how did you attach to walls?FWIW I have two length wise strips of etrack in the floor of my enclosed trailer and a row at 2’ and another at 5’ on the walls of my enclosed trailer.
they look like they're wrapped helically around an axis.how did you attach to walls?
😂😂😂they look like they're wrapped helically around an axis.
1.5 inch Self tappers on the holes that line up on the studs and deck screws everywhere else for the walls. Every single hole on the track is filled.how did you attach to walls?
Good to know that you don’t need through bolts everywhere! And my todo list when I pick up my trailer1.5 inch Self tappers on the holes that line up on the studs and deck screws everywhere else for the walls. Every single hole on the track is filled.
I did the same for the floors but used longer and bigger self tappers.
4 years of abuse and hauling stuff and everything is nice and tight still.
I’ve bent etrack d-rings winching directly on the track. It’s not going anywhere.
