P700 Engine light flashing-2 long 3 short
Sweathog
Light is flashing 2long 3 short, even when not running. What's this code stand for? Runs fine.
Any way to reset computer?
Reactions: Lady01
Sweathog
Must be something with exhaust sensor, found a loose wire at the plug to sensor under driver seat
Reactions: Lady01 and Hondasxs
63,405
Disconnecting the battery for about 10 mins "should" reset it.
I think otherwise you need to build a jumper.
I'll have more info tomorrow from the service manual.
Reactions: Lady01
Sweathog
If you have a list of the codes that'd be awesome, and worthy of a sticky in this forums imo. Only reason I found the loose wire was a stick went in that area under the driver seat and ripped out the coil wire to 2nd plug and broke off the plug. When I say loose, I mean it was 1mm further out of the plug than the other wires.
Reactions: Lady01
N
NZHONDA
6
16
new zealand
Hi Guys, great forum with heaps of info, i am currently having the same problem as above, cant find any loose or broken wires, is this just a sensor replacement or can you reset,
Cheers from downunder
Reactions: Mudwing and Lady01
41,671
Screenshot 20210416 214148
