Disconnecting the battery for about 10 mins "should" reset it.
I think otherwise you need to build a jumper.
I'll have more info tomorrow from the service manual.
If you have a list of the codes that'd be awesome, and worthy of a sticky in this forums imo. Only reason I found the loose wire was a stick went in that area under the driver seat and ripped out the coil wire to 2nd plug and broke off the plug. When I say loose, I mean it was 1mm further out of the plug than the other wires.
Hi Guys, great forum with heaps of info, i am currently having the same problem as above, cant find any loose or broken wires, is this just a sensor replacement or can you reset,
Cheers from downunder
