P500 Engine light please help... Code 1-1 MAP Sensor!
SouthernCivic
11
14
Ringgold Ga.
2017 P500 engine light blinking one short blink every 3 or 4 seconds. I assume this means 1 is the code number but I haven’t been able to find a list of codes online and I don’t have a service manual. Thanks in advance for any help getting this resolved.
68,247
Hello, Welcome to the club.
If it is in fact code 1-1 then this is a failure of the MAP SENSOR
Stand by for more.
Reactions: SouthernCivic
211,850
WELCOME!
68,247
Upload 2019 1 2 22 55 7
211,850
If it is in fact code 1-1 then this is a failure of the DTC. (Diagnostic Trouble Code)
Stand by for more.
Hondasxs stayed at the Holiday Inn last night, he's got it figured out, HA! Just kidding, he's cool and will probably figure it out!
211,850
SEE!
SouthernCivic
11
14
Ringgold Ga.
Also thanks for the quick replies, to be honest this late I was not expecting much response tonight.
Reactions: Eltobgi
SouthernCivic
11
14
Ringgold Ga.
Is there a reset procedure that has to be done to clear the light? Or should it go away once the problem is resolved?
68,247
Yes to both.
It will go away and there is a reset procedure. Disconnecting the battery for a bit works too. Thats the simplest.
The other is shorting some wires. I'll have to hunt it up because like you said. its late.
SouthernCivic
11
14
Ringgold Ga.
Was indeed a code for for the MAP/TPS. Apparently Honda insulates their wire with peanut butter.
Don’t know how well it will show up on the pic but an inch and a half section of the mint green wire is gone from the plug to where it is taped like it was just cut off with side cutters. The way the plug goes in from the bottom I could not see any sign until I pulled the air box and removed the plug again. Once the plug was turned over I still had to look close to see it between the heat shield for the cat and carb.
68,247
That looks like you had a hungry visitor. Especially since your missing a section.
Is there enough left at the plug to solder on a lead?
68,247
Glad you found it.
Where can we send our bill... hahaha.
At the dealer rate. That will be $400.
Lol.
Going to edit title a little bit for future reference.
Neohio
Neohio
Beast of the East
21,739
93,107
Painesville Ohio
Snap a pic of the connector end. You should be able to repin it wih a short pigtail and crimp. Waiting on parts will be a few days though.
