I have used amsoil 0-40 4 stroke (code AFF) full synthetic in all my off road vehicles, including my pioneer 500. Started using it in my 2002 forman 450 when it was new and has been in everything i've had. Great oil, totally sold on it, reduces required maintenance time as it lasts twice as long. Gives superior protection. Cost is about double but is offset due to the fact it lasts twice as long..
I use Honda HP4S which is a tier 3 oil but still very good. It's a 10-30 wt.
I don't believe that for our application the tier 4 oils are worth the price. There are many applications where those high priced oils should be used though. I like to use tier 3 oils in my vehicles and change them often. That way I'm performing vehicle inspections more often and will catch water in oil or low fluid somewhere etc.
To the bolded, any idea where this can be found by the gallon.
That's what I'm finding. I just want a good quality synthetic suited to the P-500 that's available in a gallon, if such exists.Are you looking for the Honda HP4s?
I was told that it's not made in gallon jugs.
I was wondering about different weight oil myself. I just bought a P500 the other day. I have used Shell Rotella T6 in all my motorcycles with good results. Is 5W40 ok in the P500? I live in Missouri and ride all year long.
I can’t imagine that they would consider the break in period for a UTV would be over 6,000 miles.So I gotta do my first oil change in the spring and I spoke to a honda service rep for some advice on oils other than what they recommend. He told me that they recommend synthetic oil should NOT be used within the first 10,000km (6,250m). Reason being that the oil is thinner (Can't quite figure that out, smaller molecules maybe?) and won't protect the engine that has not been "broken in", and that the minerals in the conventional oil will better protect the clutch since synthetic oils lack those minerals. He did say that they are suggest P5 owners use 10W40 as oppose to the recommend 10w30. This what a Honda service has told me take for what's it's worth I plan on using HN4 10w40 and when my warranty is done then move on to synthetic 10w40.
Ya cant go wrong with that plan .So I gotta do my first oil change in the spring and I spoke to a honda service rep for some advice on oils other than what they recommend. He told me that they recommend synthetic oil should NOT be used within the first 10,000km (6,250m). Reason being that the oil is thinner (Can't quite figure that out, smaller molecules maybe?) and won't protect the engine that has not been "broken in", and that the minerals in the conventional oil will better protect the clutch since synthetic oils lack those minerals. He did say that they are suggest P5 owners use 10W40 as oppose to the recommend 10w30. This what a Honda service has told me take for what's it's worth I plan on using HN4 10w40 and when my warranty is done then move on to synthetic 10w40.
