P1000 Escape Hatch
265,335
Anyone put an escape hatch on their Pioneer? I have a hard sided cabin and if i go through the ice, i want another way out. I have started looking at bus emergency hatches and marine hatches.
ICE doesn't get thick enough for my fat ass to ever get on it let alone drive a 20k+ land vehicle on it.
Can't break through if you're not on it. 🤔
Farmer
Farmer
2,851
16,389
Southern MO
Ice fishing is so fun! It is the reason I am picking up my new Pioneer on Tuesday hopefully? They keep delaying because the doors are on back order. Because of the cold, I went with a hard sided cab and heater which would lock me in potentially if I dropped through the ice.
Spring loaded glass breaker thingy?
amgdriver
amgdriver
57
143
Amelia Island Florida
This sounds like something off U tube. When the term " escape hatch" comes into the conversation it gets my attention. u might want to evaluate your methods of determining ice thickness. I took a dip through thin ice into 8 feet if water duck hunting. i dont reccomend it. Much better ways to check out than freezing to death and drowning inside a steel cage. Yikes!!!!
Reactions: Farmer
11,305
83,945
Hypothermia plan after the escape? Sounds like it would be good to go where others are close by. Glad you have the preparedness mindset to be cautious.
amgdriver
amgdriver
57
143
i went completely underwater for less than a minute. managed to use my shotgun as a crutch to dig my way out. Air temp + 5 stiff wind. I lost mental process in a few min. I had started outboard motor to try to warm my hands which was a ridiculious idea My buddy hunting on the other side of the small island thought it odd to hear the motor and came to investigate. By this time only a few min he found me incoherent walking around in circles. If I had gone by myself I feel sure I would have died. No doubt. I was working a dog on a crippled bird not paying attention to where I was walking. You go under in below freezing water u are screwed unless u have someone close by to help. Hypothermia is extremely dangerous often fatal. My son is a pro kayak fisherman boat rep. They had a ex navy seal die from hypothermia in 50 degree water after flipping over getting trapped in a cheap box store kayak. Dont go by yourself
Reactions: Mudder
