Fabric doors
HondaSXS1343
47
150
US
Looking for recommendations on fabric or others options for sides, already have the OEM windshield, roof, and back fabric window. Thanks in advance!
Sent from my Pixel 3 using Tapatalk
Reactions: ChadD and TxDoc
ChadD
ChadD
25,747
251,987
Brown City
I have siezmik doors with honda roof,hardcoat windshield and mid panel.
20200816 140539
ChadD
ChadD
25,747
251,987
Brown City
Reactions: Isaiah
HondaSXS1343
47
150
US
Thanks I like the looks of them.
Reactions: Isaiah and ChadD
HondaSXS1343
47
150
US
It sounds like some do the siezmik doors for the front and Honda fabric for the rear doors. Anyone have that setup here and have pictures available?
2018GMC
2018GMC
174
356
AZ
Anyone running Seizmik front doors and SATV 2 piece flip up windshield? Seizmik says their doors are not compatible. In that case anyone running Honda v2 front doors 0SR90-HL4-212A and SATV 2 piece flip up windshield
Framed 1/2 Upper Door Kit – Honda Pioneer 1000
$579.99
Part # 06021 | 2015 – 2018 Honda Pioneer 1000/1000-5 (Front Doors Only)
* Contact Seizmik for Windshield Adapter Bracket for Honda Windshields: 0SR71-HL4-A00; 0SR72-HL4-100; 0SR72-HL4-A00; and 0SR73-HL4-200
* Works with Honda 0SR95-HL4-205B and 0SR95-HL4-211A Back Panels
* DOES NOT WORK WITH Honda 0SU85-HL4-105 Glass Windshield; Honda 0SU95-HL4-102 and 0SU95-HL4-103 Hard Back Panels; or SuperATV FWS03-001-70 Two Piece Windshield
SKU: 06021
Reactions: Isaiah
L
Lew84
21
NW Ohio
Can you haul with the doors on? Instructions say do not but is that just a warning to protect the manufacturer
Reactions: Isaiah
Ohio4x4
Ohio4x4
I brought the dishwasher
1,528
15,413
Ohio
I pulled mine home from Arkansas to ohio with the honda gen 2 doors on with the windows unzipped and rolled up. This was the first time on the freeway but I've pulled it locally several times with the doors on and windows zipped closed.
Reactions: Isaiah and TripleB
Jacks
Jacks
320
1,527
South Dakota
Ordered my Honda soft uppers (HL4 212A) for front and Honda soft mid panel. Cant do the seismic uppers because of my SATV flip up. Gotta make a move as it’s getting cold out. 9 degrees this morning.
2018GMC
2018GMC
174
356
AZ
How did the honda upper doors work out with the SATV flip up windshield?
I may get door bushings to tighten up the door slop before getting upper doors in hopes of a better fit.
Reactions: ChadD
Jacks
Jacks
320
1,527
South Dakota
I guess I'm happy with the fit for the most part. Definantly keeps a lot of weather out. I have to slam my door shut a little harder than what I was to get them to latch but they seal up good. Mounting brackets pop rivet to the inside of the door with 12 rivets each. There is a plastic receiver that the leading edge of the door frame snaps into when closing and this really helps firm up the seal when closed. I've had my machine up to 55mph with them on with no problems at all. If you have slop in your door hinges you will want to fix that first for a better fit. They install fine with the SATV flip up but you will obviously have to do some sealing around the windshield so that's next. Honda mid panel works well. Installs easy and tight. . We will see how the product holds up. It is well made.. Just got my Inferno cab heater delivered yesterday so will work on installing that.
TripleB
TripleB
15,251
136,268
Caryville, Tennessee
I have the same set up as you do minus the heater and I'm happy so far. Only had 2 kinda cold rides and then it got warm again here.
2018GMC
2018GMC
174
356
AZ
Sweet! Thanks for the detailed reply.
I have Honda mid and rear panel now. Would be nice to get rear doors as well but will start with just the front. For some reason Honda rears are more than the front. You’d think they would be less since I bet they mostly just sell fronts.
Reactions: ChadD
askerlro
askerlro
5
10
Grantsville, UT
Jacks is exactly my experience. I put them on last weekend along with the mid-panel. I have to slam my doors a bit to get them to latch but it's not horrible. Fit is actually pretty good once centered, mounted and perimeter trim pieces are tweaked a bit. I'd do it again. Good luck!
Reactions: 2018GMC
russknight
russknight
1,910
7,510
Perry Florida
The Honda mid panel is flimsy junk.
