Can anyone tell me what parts and modifications are included in this fix? I had it performed by my Honda dealer and I am not sure everything was done. One thing is for sure, the improvement is negligible.
I haven't had the Honda fix done because I've read that others have the same findings that you have, so I can't help you there. What I, and many other members have done is, use an insulated foil backed heat shield available from a retailer such as Summit Racing and make your own one piece shield that goes from the front edge of the seat bottom, behind the black plastic seat space cover and then up to the top of the seat backrest. If I remember, I think the only holes (slits) are for the seatbelts, the two front locator pins and the center seat latch. You'll still feel some radiant heat but it completely stops the hot air from sucking up through the engine area.Can anyone tell me what parts and modifications are included in this fix? I had it performed by my Honda dealer and I am not sure everything was done. One thing is for sure, the improvement is negligible.
Been there done all that stuff, only answer is a fan! Which I need to do!I haven't had the Honda fix done because I've read that others have the same findings that you have, so I can't help you there. What I, and many other members have done is, use an insulated foil backed heat shield available from a retailer such as Summit Racing and make your own one piece shield that goes from the front edge of the seat bottom, behind the black plastic seat space cover and then up to the top of the seat backrest. If I remember, I think the only holes (slits) are for the seatbelts, the two front locator pins and the center seat latch. You'll still feel some radiant heat but it completely stops the hot air from sucking up through the engine area.
Thats what I used, but when it's really hot, it's hot in the cab, it does help a lot but not enough on really hot days. The heat comes up between the back of the seat and front of the bed. I'm going the fan route in addition, got to get this done before Bear Creek get together.Go to lowes and buy this. Take the seat bottom and back off. Run one continuous piece across the machine with it flush to the front of the seat and wrapping up the back. Cut around the seatbelts and put the seats back. Oh can ride with no fan and it's made a huge difference.
Shop Reflectix 100-sq ft Reflective Roll Insulation (48-in W x 25-ft L) at Lowes.com
Fuel system recall!!?? Was that VIN specific?I had the seat heat fix done when I got the clutch and fuel system recalls done. Seems that the rubber sheet material is their go to. I noticed no difference but I did my 7" fan install already so it was already much better. If I get the time, I may add the bubble-type insulation just for grins.
The guys at the dealership were well impressed with the mods I made... dual battery, vent relocation, switch panel, lights, etc... with insight from you all. Appreciate it!
FredD
Oh ok, that one. Thank you RF.I meant this one...
CPSC RECALL NUMBER: null
Campaign Description: 16-18 SXS10 THROTTLE BODY RCLL
mfr campaign id: KJ6
recall date:
recall status: VIN/HIN Required
Summary:
PIONEER 1000 THROTTLE BODY MIS-INSTALLED
SAFETY RISK:
ON CERTAIN VEHICLES, THE THROTTLE BODY ASSEMBLY WAS NOT INSTALLED PROPERLY TO THE INTAKE TUBE. IF THE THROTTLE BODY BECOMES DETACHED FROM THE INTAKE TUBE, THERE IS A POTENTIAL FOR FIRE.
REMEDY:
CALL ANY AUTHORIZED HONDA POWERSPORTS DEALER AND MAKE AN APPOINTMENT TO HAVE THE THROTTLE BODY INSPECTED AND IF NEEDED, CORRECTLY INSTALLED, FREE OF CHARGE. INSPECTION AND REPAIR OF THE THROTTLE BODY WILL TAKE APPROXIMATELY 18 MINUTES TO COMPLETE. PLEASE ASK YOUR HONDA DEALER FOR THE SPECIFIC TIME YOUR SIDE BY SIDE WILL NEED TO STAY AT THE DEALERSHIP WHEN MAKING AN APPOINTMENT FOR THIS RECALL REPAIR. SHOULD YOU HAVE QUESTIONS ABOUT THIS RECALL OR NEED ASSISTANCE LOCATING AN AUTHORIZED HONDA POWERSPORTS DEALER, YOU MAY CALL HONDA POWERSPORTS CUSTOMER SUPPORT: 1-866-784-1870 OR USE THE FIND A DEALER OPTION ON WWW.POWERSPORTS.HONDA.COM
Read more at Recall Information - Honda Powersports
FredD
