P1000 feels tippy and squirrelly with new tires/wheels and spacers
dutchsxs
58
102
Wenatchee, WA
Ever since I upgraded tires, wheels and spacers I feel like the UTV is tippy and squirrelly almost like driving with one empty tire when initiating a turn like it want to break out oversteer. I have gone from 10 to 15PSI on the tires played around with diff spacers (sadly couldn't return to old setup as I had a blown tire), but can't seem to fix it is there something I am missing here or an adjustment that I am forgetting?
Using:
Pioneer P1000-5 deluxe
Tusk Nebo 14 inch Beadlock Wheels 5+2 offset
Tusk Terrabite radial tires 28x10R-14
SuperATV spacer 1" (front)
SuperATV spacer 2" (back)
Thanks!!
69,049
I'd Play with the toe. Mines best when it's out around an 8th. Otherwise it's darty on blacktop. 30s with super atv arms no sway bar.
dutchsxs
58
102
Wenatchee, WA
any suggestions on how to
Also may want to tighten up the suspension if you got fox or aftermarket
All stock, besides the changes mentioned. Looked up how to adjust the toe and move it inward, found some videos how to do this on youtube. Thanks!!
Mopower58
Mopower58
CST is the Best!
79,522
706,928
Crystal Springs,Ms.
Remove the spacers and test.
Or remove the front spacer and put only the 1" in the rear.
Unless it's needed, I would also put the 1" spacers in the rear and put the 2" spacers on the shelf. Tipsy or not. I've got the 5+2's with 28's all the way around and did away with the sway bar 6 years ago. However I'm not an aggressive driver.
60,304
Terrabites hook up awesome, cross rutted and it gave me the business. If you squint, it's mint!
 V9PmTOIfUK1WOrEvq6WNzAw1173 h880 s noauthuser0
60,304
That said, I think I've got close to 3k all- over miles on these things. They are really hard to beat for a trail tire, or were when they were $110 a tire. I went back and looked a few minutes ago; I paid $1198 for 5 tires and 4 wheels shipped from RMATV
Shelly
184
514
Shelly
184
514
Is there a wheel spacer brand you like better than another, or does it matter?
