P700 Few more mods to the old girl
swsebek
swsebek
2,854
5,828
pa
Finally got around to changing the front and rear gear oil.And it looked as good as the new stuff I put in.Changed the oil and found out I was missing the filter shim o-ring again.Went to Lowes and got this one and flapper wheeled it to size.It was almost perfect size only removed about .030 in.dia
IMG 4551
swsebek
swsebek
2,854
5,828
pa
IMG 4635
IMG 4637
IMG 4630
Also put on 2 sets of rock lights. Red underneath and blue up top for good interior lighting. Made whip mounts. And added 4 more rockers under shifters
swsebek
swsebek
2,854
5,828
pa
IMG 4643
What did you cut them with? The ones I say were heavy an about 3/8s if I remember right.
It took a little finesse.I had a piece of cardboard and I made a pattern, then I flipped the mat and pattern upside down and sprayed white painted on the edges. I then laid it down and cut on piece of plywood.A couple of trim cuts and it laid down nice.
Just be careful and don't try to cut through at one slice.the mat was 2'x4' for 24.99
And I have enough for a second one.
swsebek
swsebek
2,854
5,828
pa
swsebek,
looking at getting I think the same style mirrors see link please.SEIZMIK PURSUIT SIDE MIRRORS 1.75in diameter Lifetime Warranty HONDA PIONEER | eBay
are these what you have how to you like the fit on the roll bar?
No mine are the strikes. But they look alike they are 65 bucks. And they are composite plastic. The pursuits are aluminum.They will fit the 1000 ROPS better. I had to shim mine. The 700 has a 1 5/8 dia.bar.
They are good quality and I'm very pleased.The sight area is nice
IMG 4649 IMG 4650
319,920
Love the lighting! Real nice job on everything looks great
Reactions: Tflynn and swsebek
Tuco69
Tuco69
1,474
7,563
Middle Georgia
View attachment 78459 It took a little finesse.I had a piece of cardboard and I made a pattern, then I flipped the mat and pattern upside down and sprayed white painted on the edges. I then laid it down and cut on piece of plywood.A couple of trim cuts and it laid down nice.
White paint on edges?
swsebek
swsebek
2,854
5,828
pa
You could use a sharpie marker too. The paint makes an outline of the cardboard so you have a outline to cut.
