Multi Fight Corona boredom during stay at home orders
my buddy 1 lung gerry just got himself a new smith and wesson so we're going to make big holes in stuff tomorrow.he wants to try mine with the wood stocks so he's supplying the ammo.
Well that’s good. I was considering the expense to you today reading off your list earlier....
Reactions: Biteme
Vikes79
Vikes79
SKOL!
10,884
105,609
South Dakota
  2. Talon X4 LV
I can’t tell if it’s that loud as my Allis roars pretty good at full throttle. I wear hearing protection when running it.
Its a Wallenstein brand chipper.
Here’s a clip of me (the fat guy) putting in a 2.5” diameter spruce branch into it.
Yeah the self propelled ones have those high rpm motors that are really loud. What rpm is your tractor on?
Vikes79
Vikes79
SKOL!
10,884
105,609
South Dakota
  2. Talon X4 LV
The chipper is installed with a 540 pto shaft connected directly to the flywheel of the chipper.
What is actually delivered to the chipper by my 1954 Allis WD45 w/o a tach is anyone’s guess. It’s probably a bit over speed like 550 or so rpm.
Reactions: Montecresto
Experience?
22E1FE07 AE3F 41D4 92C8 C97573389263
Well that’s good, I thought you said you were running the tractor at full throttle. 👍
Is that really necessary (or even good for the tractor) seems like half throttle would be sufficient. I have only rented and used one once and believe 1300-1500 is what I had mine set at....🤔
Vikes79
Vikes79
SKOL!
10,884
105,609
South Dakota
  2. Talon X4 LV
All our farm tractors actually use less fuel running at pto speed for pto equipment vs trying to lugg them at lower rates. Some of our tractors have a two speed pto (I.e 540 with an overdrive) that allows for the engine to run at a lower speed but maintain pto rpm on lighter duty equipment but we rarely use it as it places much higher stress on the tractor driveline which is much more expensive to repair vs 1 or 2 gallons of fuel per hour.
Reactions: Plumber32
I see, my pto speed range is between half and full throttle, but none of the tractors are vintage either so there’s no doubt system differences. Anyway, cool implement and you can work without spending much money right now...👍
906UP
906UP
13,030
121,470
da Yoop
So Home Depot, nearest is 80 miles away, will deliver during this sh#tshow, for less than a buck a mile one way....SOLD. More materials are ordered, may take a few days before they get here but I've got time 🤔
I'll make sure to give the driver a good tip 😊
906UP
906UP
13,030
121,470
da Yoop
Waiting on some materials for the LR remodel so today I hooked up a 12v fan & digital temp controller in the enclosed trailer to try and exhaust some hot air in the summer months when it's used for snowmobile storage.
rickoshea
it was -10 , 20 km/h wind and snow flurries so of course i had to do a few laps around the lake to stave off boredom.the wife is in the window giving me the bird because she's working and i'm dicking around outside.now i'm home trying to get feeling back in my feet.rubber boots weren't the best footwear choice,but a couple baileys and coffee should help.
20200331 134813 20200331 135055 20200331 135739 20200331 134826 20200331 134742
