Finally got rid of the bench seat
Srchamberlin
34
61
Ohio
Also added some modifications for my daughter , she is 25 and has CerebalPalsy and does not have the ability to sit up on her own .
Saw a video from another member that used same seats to do an install on a 500 .
Did kinda the same setup but added modifications for my daughter , worked out awesome
20180921 203146 20180921 203120
Todd627
Todd627
56,720
619,275
MI
Dang!!!! That is awesome!!
gullyjumper
gullyjumper
950
2,413
cookeville tn
Looks really good she'll have a great time in a custom ride.
322,690
Very well done! Looks great
Reactions: Remington
208,726
View attachment 87678 View attachment 87684
Very nice! I bet it makes her day/week! What's her name? She should become a member, I would love to talk to her on the site???????? And ride with you guys? I don't care if you are short, tall, skinny, fluffy, I will give you a ribbing , just for cause!
Srchamberlin
34
61
Ohio
Srchamberlin
34
61
Ohio
Ok here is some more pics
Of course I used the RZR seats. then I cut out a plate the size of the opening on the bottom of the pioneer 16x16 and I trimmed it to fit.
I attached the seat base from the razor seats without the frame to the metal plate then attached it to the pioneer. I am going to attach the rubber grommet that holds it in place but for now I just use screws to hold it in. I took the seat frames and attach them to the box then I cut them so that the bottom that attaches to the base was not on them I cut it just above the elbow. Then I attached the back of the seat with the frame 2 the square mounting bracket for the bench seat back. I had to add a steel plate that attach to the back of the frame and then attach it to the bracket on the pioneer hopefully you can see it all in the pictures
I decided to cut the bottom of the frame off to help the seats set lower for a lower profile when I added the seats in there when they still had the full frame, and it set up really high and I didn't like it and . my legs were too close to the steering wheel so that's why I ended up just cutting the frame of a seat and just mounting the base to the plate without the frame.
and for those of you that like the looks of it in The Stance because of the wheels in the tires I have.
I have 27 by nine Swamp Fox tires on the front and 27 by 12 Swamp Fox tires on the back the rims are a set of take off that I got from a friend off of a a Kawasaki Teryx. I had to use a spacer to adjust for the lug pattern. But this gave me two more in the ground clearance perfect for the mud in the trails
20181010 150106 20181010 150014 20181010 150112 20181010 150051 20181010 150023
Srchamberlin
34
61
Ohio
View attachment 89919 View attachment 89920 View attachment 89921 View attachment 89922 View attachment 89923
20181010 151833 20181010 151904 20181010 151904 20181010 154217
