As the title suggests, I finally installed a plow on my P1000. I haven't seen this type on here before so I thought I would place it on here as an additional option. It is the ClickNGo2 72" plow by Kimpex. Overall I am very satisfied with the construction and design of this plow system. It is a mid mount which I really like as it has minimum effect on the suspension due to weight distribution. Clearance is typically a problem with mid mounts, but they seem to have solved that with a pivoting push frame which allows you to lift the plow higher. I haven't had a chance to try it out yet, but just wanted to give you guys another option.
