P700 First Service Done P700 Deluxe ....Summary
Deluxe700
Deluxe700
856
1,101
Central Arkansas
Picked up my P700 Deluxe today from the Dealer as I dropped it off yesterday for it's first service. Normally I have always done my service work, but on this machine, I decided to let them check it over this first time. I didn't really have any complaints or issues.
I really like my dealer and have used them for MANY years, so I do trust them.
The valves were just a tad loose , so both exhaust and intake were adjusted.
The front toe out (or toe in), was out so this was adjusted.
I made the decision based on my past experience to go ahead now with the switch to Full Synthetic Honda Pro 10W30 oil. I know some folks say wait a couple or more oil changes. But with the way the 700 uses the engine oil for the torque converter/transmission, I decided to go ahead and make the switch.
The P700 Recall for the seat belt thing did NOT affect my unit, but that was checked to make sure.
So, she is back home and running like a champ.... I was waiting till after I did the first service at the dealer before I started adding my "goodies" . I have everything already bought that I want to add or modify, just been waiting for 1st service at the dealer to get done.
Reactions: Mudwing
Mudwing
Mudwing
36,959
306,672
The Mud holes
@Deluxe700, did the dealer say how much were the valves out of spec?
Deluxe700
Deluxe700
856
1,101
Central Arkansas
Yes...I'm sorry , but i don't remember the exact amount, but it was very minimal from normal spec. I was skeptical about valves even needing adjustment at such a early time into a new machine..I thought it would need to have many more hours or miles before adjustment would be needed. I have ran ATV's in the past for a very long time before even checking the valves...But...according to the dealer (as I said I have used them many years and trust what they say), they say that almost ALL the P700 machines and Rincon's I would think....need the valves adjusted at 1st service. They say that some of the other model Honda ATV's hardly ever have the valves out of spec at 1st service. I did NOT notice any valve noise before the service, but as I said it was a very minimal adjustment.
Mudwing
Mudwing
36,959
306,672
The Mud holes
Thanks for that. It was a good call having them do the first service. I've already done mine with the exception of valve clearance. I guess I will plan to do it soon. By the way, I'm at 200 miles.
Deluxe700
Deluxe700
856
1,101
Central Arkansas
Yeah , Might be worth checking the valves when you have time. If what they say is true, there is a good chance one or both could be a little out of spec. I was at 130 miles at 1st service.
swsebek
swsebek
2,854
5,835
pa
Some machines are out and most are not out on first service.Is what I have seen over the years.
My valves were checked buy the dealer at 1500 miles and I was still in spec.
Honda rincons are easy to hear the valves asking for help. But the pioneer I'm not sure you can hear it as good
Reactions: Deluxe700
