G
I certainly hope you got a kiss and a foot massage at the minimum . EZ to do yourself . First time might take you 2 hours and 100.00 worth of oil and filters .Is $650 normal for a first service ??
Valve clearance check is a WASTE . Just do it and keep record of what you did .That was all fluids changed air filter and valves checked $650 just seems a little excessive?...
Said 4 hours labor !
Under maintenance schedule, the owner's manual says the following for Inspect Valve Clearance: "Inspect valve clearance as needed, if engine is noisy." (Page 128-129).Haven't had it done yet ..I was more concerned about checking the valves and documentation for the extended warranty?
I have physically checked about a dozen machines and only one was out of spec and you could definitely hear it. Mine is now starting to get noisy at 4000+ miles and will be getting adjusted in the next couple weeks.Under maintenance schedule, the owner's manual says the following for Inspect Valve Clearance: "Inspect valve clearance as needed, if engine is noisy." (Page 128-129).
Your dealer recommended they do it to generate revenue.Mine was about $330.... My dealer recommended they do it so that it was documented with Honda, should there ever be an issue with warranty it shows the dealer performed the first service... Just a thought.
