F
Has anyone flat towed their Talon?
Does someone make a nice tow bar for it?
Talon has a locked rear end, not sure you'd want to drag that around behind your RV/CamperHas anyone flat towed their Talon?
Sounds like baby seals being clubbed when you turn!I don’t even like driving mine on pavement (even though it’s legal for me to do so locally), let alone tow it.
Do they not allow trailers in Californistan?Has anyone flat towed their Talon?
Like I said on the other forum, a couple miles (maybe even 5) under 30mph probably won't hurt the machine but just remember...Thanks for all of the feedback.
BTW, I have two trailers that are very capable of towing my Talon.
Still want to know if anyone has flat towed their Talon?
This right here. You’d have to remove drivelines to do it somewhat safely on the machine. Don’t think things would get proper lubrication without.Maybe if the machine was running you could remove some risk (oil moving in the tranny), but why even consider it?
Just toasting one component in the drive line will make renting a trailer, or getting an SD license and driving it on the highway look silly cheap.
Well said, G21U. I've done one-off projects my whole life that worked well for me but made no sense to others.I agree with @CumminsPusher on the lack of lubrication as a possibility and potential damage to the driveline due to the locked read axle.
Other than that I am uncertain of any other reasons and maybe someone who does will chime in and say what they are and not just post bad idea don't do it
I often times find people with little to no experience or even the fear of the unknown say things are not a good idea and shouldn't be done
With that being said I am certain that with enough prep work and forethought it is entirely possible and safe to boot.
The simple truth is the amount of work to flat tow may or may not be worth it to you, not me or anyone else.
It's your machine and as such it is your decision.
Just maintain safety for you and the public around you no matter how you proceed.
Good luck.
I too have done weird or as some might say foolish projects and have heard a fair amount of feedback both good and bad.Well said, G21U. I've done one-off projects my whole life that worked well for me but made no sense to others.
Maybe if the OP told us why he wanted to do this, we could come up with better feedback.
My reason is as Paul stated above. I came up with 4 ways to get my Talon to the trail head when I’m not camped with direct access.Like I said on the other forum, a couple miles (maybe even 5) under 30mph probably won't hurt the machine but just remember...
Not sure your reasoning but I have a toy hauler and have run into the need to get my machine to a trailhead 10-15 miles from camp. I have pondered and pondered this dilemma but did not resort to flat towing and just made mine street legal and drive to the trailhead instead. Someday, this will come back to bite me
- The manual specifically says not to for a reason.
- Pavement and corners kill the rear inner CV joints, especially with higher traction tires.
- Stock tires are s*** on pavement, DOT approved tires will do better.
- You must have working tail/brake lights.
- Some states require anything towed over 1500 lbs must have brakes tied to the tow vehicle.
- Some states require any towed vehicles (regardless of weight) to have brakes tied to the tow vehicle.
I think I will build something like this and throw it in the bed when I know I will be needing it...
Short Wheelbase TrailHead Trailer Components — AA Offroad LLC
Need a way to get your UTV from the toy hauler to the next adventure? AA Off-road's Patented Trail Head Trailer allows you the freedom to access UTV adventures away from the campsite. The trail head trailer disassembles with a few pins and can be carried in the cargo area right along side your UTV.www.aaoffroad.com
Easiest seldom happens for me....... it almost always ends up being the most expensive also. I'm interested to see what you decide on! Good luck and happy wheeling!............
The easiest, other than driving it there is to flat tow it.
I just had a flashback - this same question was asked a year ago (?) about towing a Pioneer 1000 ~5 miles. After learning why, it was decided that no damage would happen if he did. I'd never be able to find that thread though. The P1K and Talon have somewhat similar drivelines. YMMV
Totally different towing it back 10+ miles on the trail vs towing 70mph behind a truck with no driver.I just had a flashback - this same question was asked a year ago (?) about towing a Pioneer 1000 ~5 miles. After learning why, it was decided that no damage would happen if he did. I'd never be able to find that thread though. The P1K and Talon have somewhat similar drivelines. YMMV
