For those that get wet
MarylandMark
17
27
Maryland
'18 Honda P1K-5 LE owner here. Might be a stupid question but are these things built to get wet? I see snorkels added but what do you do or does anything need to be done to protect the stock wiring? How about added wiring like for a 2nd battery, winch, fuse block, etc? Dielectric grease by the gallon?
Russ989
Russ989
22,645
147,291
The P1K5D is a tough machine. It will take quite a bit of water as long as you keep your air intake above water and it won’t hurt to add some dielectric grease to your components and harnesses. You’ll also want to extend your vent lines for the front and rear diff and the gas tank. @Bayouownbeer sells the vent line kits I think.
Alan_Vander
Alan_Vander
1,547
2,752
rosepine,la
All the electrical components have seals and are water proof. Sometimes seals on the plugs do let water in ie... Coil, spark plug things like that. But the gauges are sealed component. I did my 700 and my cj7 with 1 can of the pressurized dielectric grease from auto parts store. 6 yrs ago. Also still have the same little bottle i use on my trailer wires here and there. Winch selenoids should be water proof winch itself usually isnt but water doesnt hurt the motor. Sand and stuff hurt the bearings which is why its good to wash everything good after wards.
aauman88
aauman88
1,091
2,846
Vent lines and snorkels is really all you need. And yes wash it off after
2212975E 90C3 4B63 8B2D BC5B527C7C16 7614E9FE 769D 4D7D 81B1 564D962675CB 26924927 4541 400F 983E 664F3C5C162C
MarylandMark
17
27
Maryland
Thanks! I did an okay job with shrink wrapping the crimps and the wires but wasn't sure what to do about the exposed parts.
I have a Mighty Max 2nd battery w/Stinger and isolator, LT4000 Superwinch, Blue Sea Systems fuse block, PBR switch panel, Corbin turn signals with horn, just got my Brick City cooler/tire holder, few floor LED's (ran in to the fence when I couldn't find the brake one night..), vent line kit listed above just showed up, Honda roof, Honda split windshield, fire extinguisher and a rear mesh panel.
Reactions: TripleB
Dirtstiffs-1000
Dirtstiffs-1000
1,729
6,240
hondasxs.com
Just ride it
Bayouownbeer
Bayouownbeer
798
1,123
Chauvin LA
Hondoman
Hondoman
727
1,697
Texas
