P1000 Forward A-Arms and lug adapter questions
  • Thread starter Bigmanlittlebuggy
  • Start date
P1K5Dave
P1K5Dave
2,285
8,545
Petoskey, MI
You should read thru @aauman88 's thread. He built his into a monster mudder in several stages. Lots for you to learn from if you're going big:
SuperATV
SuperATV
1,390
9,730
Madison, IN
www.superatv.com
To run 35"s, you'd need at least our 6" full suspension lift...on top of 4" or 6" portals. If you did the 6" on 6" you could run up to a 37" Technically the 6" lift and 4" portals are rated for a 34" but your 35"s will likely run short and you can probably get away with it.
If you're looking to go really really big....those 20"s will work fine with 4" and 6" portals.
Without portals....you're going to be tapped out at about a 30" or maybe a 31" with some rubbing if you use our forward A-arms.
Bigmanlittlebuggy
Bigmanlittlebuggy
158
442
Ellabell GA
So I have a limited edition model and haven’t seen a 6 in lift kit offered only a 3 in I will be doing portals some day maybe when I hit the lottery lol 😂 but thank you for the advise was very pleased so far with my depth finder snorkel I bought from super atv
G
Gohonda2
46
252
Mississippi
I know this info won’t help you out with the p1k but I have 33s that measure true on my talon r with no rub whatsoever. Stock no lift.
F37AF8F2 5472 4CD1 AC13 A9864A5F846D
