P500 Front CV axle Disassembly Question
Jbratt78
Jbratt78
16
64
Spring, TX
Is there a trick to separating the cv axle shaft from the outer cv joint? The inner is simple, you just remove the retaining ring, slide out the bearing assembly and remove the snap ring. The outer cup has no retaining ring and I can't see a recessed area providing access to an inner clip like on some atvs. Is this just a bigger hammer situation or is there a special puller or other tool? Any suggestions are appreciated. Thanks.
Jbratt78
Jbratt78
16
64
Spring, TX
906UP
906UP
14,237
134,905
da Yoop
Because I am doing something completely different that will require a custom length shaft and I need the stock one for R&D purposes. I bought a cheap used one on Ebay for just this purpose but I can't get the damn thing apart so far.
Ahhh....understood.
lee
lee
Village Idiot
2,383
13,486
Springfield Ohio
How it goes together (and why you cant take it apart):
The cage is put in at 90* to its normal orientation.
The inner star is inserted - sometimes the cage has a set of larger windows to install the star.
As the cage and star are rotated in to position as the balls are installed.
The axle is inserted, there is a C-clip that snaps in to the holds the axle.
(once the axle is installed, the inner star can not rotate enough to let the balls out)
The C-clip is the problem.
It can take 3,000lb of force to get the C-clip to let go.
Speaking generically, I have heard of people holding the axle and striking the inner star to get it to release.
This is not a honda sanctioned method and can result in damaged parts.
Jbratt78
Jbratt78
16
64
Spring, TX
Thank you for the information, that is very helpful. I think I know the next step in this little adventure now.
