P500 Front end lift ??
maddmax
257
231
Clarksdale Ms.
What would be the best way to lift just the front just about 1"or 2" ?
Gator
Gator
The Most Unknown Member
2,476
10,399
Louisiana
Best??? Depends on what you mean by "best"
A shim/spacer in the shocks is the simplest. IMO
Lift kits are available and work very well. (most widely used method)
Longer shocks could provide a better ride AND lift.
Arched A-arms would be great and add clearance.
rocmar
rocmar
4,741
5,775
4 CORNERS
2 ton
floor jack
bigbore
bigbore
218
269
I'll also suggest larger tires although I don't like to go too large. I believe I read that tires should all be the same diameter so that they turn at the same rate in 4WD, so you'll have to raise the back too, darn it.:eek:
jak9922
jak9922
hot headed wopolock
3,296
5,681
pittstown ny
cheapest easiest way would be spacers but that also preloads your springs so the already stiff shock would be even stiffer
maddmax
257
231
Clarksdale Ms.
don't want to stiffen my spring,so I guess i'll relocate my shock brackets.But thanks for the input guys
Reactions: Montecresto
