As bad as the front shocks are this will only make the ride worse. Adding weight that far forward will reduce the capability of the shocks to absorb hits.
That said if you ride slowly it should be acceptable.
Thanks Vince! I will get one ordered, this will help with lack of storage when back seats are being used. Do you loosen the wing nuts and it will swing up for access front hood?
