P700 Front tires out of lign
cjm
6
My front tires are outta lign. Any advice on how to relign them with out having to take it to the shop ??? Thanks
Has it always been that way? Or did it recently happen?
I ask because the 700 can have a problem with suspension components coming loose from the frame.
This was after hitting a tree. (I know, my fault. Not Hondas).
Db0df2eab634fc9bea3a0c786e848113
This is a weld repair at the group ride in AL last fall.
2977e2093f13f83314809fc097d9fa82
Here is what happened to another member at the same event. These are A-arm brackets, so they can definitely affect alignment.
65fa5a8efc4613ec80e0f31b1d6ae754
If all is well and you just need an alignment, I guess we can help with that too.
cjm
6
It just started. I bent my lower A arm. So I replaced it but it stills pulls the the left when I drive it
It's not science, more like redneck but I used two yard sticks and adjusted it until it was the same front and rear.
Dcdc1110c4142fa97b96141c827c124b
I know some people say that you should have a slight toe out. That's true, and should be followed for automobiles. I didn't worry about it because this is a off-road vehicle. I did not have any trouble.
