P1000 GBC Terra Master
60,305
These look pretty cool:
RMATV Link
Upload 2019 10 3 11 35 58
Upload 2019 10 3 11 37 27
Russ989
Russ989
22,642
147,257
How does he like them? I'm not in the market for tires but I've added these to my list to consider when I am.
Those are what I’m buying for the Trifecta 1000-5. You’ll be able to see them at the takeover.
Bad_bowtie
Bad_bowtie
Huge member
2,540
15,624
East Tennessee
Definatly an interesting tire. I wonder if it really matters which direction they are mounted? I see that part as a gimmick, but they do look like they would do very well around here in everything except deep mud, which I dont care about anyways. I do like the 10 ply rated part!
69,049
According to dirtwheelsmag it does make a difference as to placement
Vikes79
Vikes79
SKOL!
11,702
113,528
South Dakota
  2. Talon X4 LV
I was just looking at these. Might be a good combination tire.
Reactions: Bad_bowtie
Russ989
Russ989
22,642
147,257
So which way is better?
I think side B is for hard pack and side A is for soft terrain. I figured it didn’t really matter but the article I read said that most of your rigs weight transfers to the outer part of the tire.
ToddACimer
ToddACimer
Pioneer 1005-2
3,671
15,504
Oshkosh, Wi
So if I mostly ride in wet sand or hard packed gravel which way do they go? Cool idea but I don't know how you'd know they worked well.
Reactions: Russ989
Russ989
Russ989
22,642
147,257
Not sure, I think they will do good no matter which way you mount them.
Reactions: ToddACimer
69,049
For loose sandy terrain you want the knobby side inside. Dirt wheels. Ran them then switched them around on the rim's and ran again. They are tough but seem to run short by a decent margin.
