P500 GREEN RIBBON STRIP FUN LIGHTS
rocmar
rocmar
4,741
5,775
4 CORNERS
Removed roof....the sticky
on them...sucks...not sure
I'm a fan...the wife is...secret
is to hide um...& just get a glow
wired into the stereo. ..
Very Bright green .......
20160809 185532 20160809 185543
rocmar
rocmar
4,741
5,775
4 CORNERS
Oh....& Battery PaK
also was perfect
for these applications
getting power to lights
to make sure of placement
before running wires....
Gator
Gator
The Most Unknown Member
2,476
10,399
Louisiana
I'm thinking you need a good quality (3M?) two sided tape.
rocmar
rocmar
4,741
5,775
4 CORNERS
Yeah...a good adhesive
is needed...
that's why I took top
off...more lights to come
.....eagle eye ....day time
running lights (6)..... 1"
and a light for the back
....not to back up....to see
when getting in bags...
or cooler....
should be here today
162,123
is needed...
or cooler....
Uh oh, someone got bitten by the light bug...
you been hanging around cummins pusher? :)
Reactions: Eltobgi and rocmar
rocmar
rocmar
4,741
5,775
4 CORNERS
First pic is off windshield
next is glow of cab....
20160810 200001 20160810 195921
Reactions: 500oneer
rocmar
rocmar
4,741
5,775
4 CORNERS
It's only 1/2 dark.....
gonna have to tame
that down
Reactions: Eltobgi
webby
webby
123
182
Philipsburg, Pa.
View attachment 19903 View attachment 19904
I like that! I thought of doing something like that for a bit of light in the cab (didn't know what exactly).....my VDP Soundwedge ended up havin 2 blue LED's built in. Got lucky. It does seem bright, I bet you'll like dimmer a little better.
Reactions: rocmar
rocmar
rocmar
4,741
5,775
4 CORNERS
I'm gonna hide the back ones
a little better...or make it shorter
webby
webby
123
182
Philipsburg, Pa.
Are they segmented and easy to adjust length? I've installed under cabinet lighting that was easy to work with and modify. That stuff was 120v/24v step down. Hopefully the stuff you have is easy to change.
rocmar
rocmar
4,741
5,775
4 CORNERS
Yes can cut every 2"
rocmar
rocmar
4,741
5,775
4 CORNERS
Reactions: Eltobgi
Jshell3
I used almost those exact same LED strips on my aluminum boat (except Amber color).
I know what you mean about the adhesive backing (weak)... But it's been just over a year, and I've had no issues.
Even stuck on the outside of the hull like this.
LED boat2
