43,488
Looks like ins is coming to get it shortly and your saving all you can. What’s buy back, states very but usually it’s approx 20% of used retail unless the salvage facility guarantees a higher amount based off of previous demand.
Would be worth buying back if you could just for the $10k engine that isn’t available from factory as a crate. Plus trans, diffs, frame, bed, seats, clutches, headlights,doors and misc stuff someone could do a killing on. Probably worth 15k parted out. Pioneer is a very expensive rig to fix. Been there a few times from factory issues but I wish I had been able to have cash to do buy back, it’d be 10k in wallet instead of out.
The 10k engine is one of the things that potentially scares me about buying a 1K. I guess I try and look at the worst case scenario sometimes.
Would it be safe to say that the 1k is much more "automotive like" than the semi lawnmower engines in the 500/700?
Mopower58
Mopower58
Unburdened by what has been!
83,345
729,068
Crystal Springs,Ms.
Never had a 500/700 but I would say yes.
Neohio
Neohio
Beast of the East
21,565
91,451
Painesville Ohio
I'll have to look tonight. Not sure
Looks like you might have enough room for a 1/4" air ratchet and 10mm to remove it.
If will still be tight with a stubby 5mm to remove the cover. Good thing about it going to auction, you can pile all the parts back in it in a box.
If people see it in pieces, they will wonder what happened and whether it runs. Should really affect the final value when it goes across the block. Could be nasty and disconnect a few sensors so it won't start. Then keep googling the VIN to see where it ends up for auction. Go and buy it cheap!
Don't forget the BCF bar!
322,855
I’ve been faced with that engine twice and it’s brutal. Some parts aren’t available still as far as I know. But the positive is it’ll last a damn long time because of the tolerances. Just doesn’t like water or dust.
Yes it’s automotive style. No jugs. That’s why I won’t let just anyone drive it anymore, save that for the Wolverine.
Russ989
Russ989
22,642
147,257
You just talked me out of really wanting one. :cool:
ToddACimer
ToddACimer
Pioneer 1005-2
3,770
15,959
Oshkosh, Wi
Harness bar is bent. Machine needs to run and roll when I return it
322,855
Hey @Tigermark lol
7765DE46 3D7F 4F7F 992A 6825FAFE4DA8
70,091
Funny just a few short months ago, my significant other was hounding me on why do you need 2 windshields, and everything else. Now look who put on an emblem and guess what a 2nd windshield lol.
20190516 160030
322,855
Man that looks good
