SpeedBuggy
SpeedBuggy
1,289
10,214
WA
I’m not sure what everything going on here is but this is awesome
DA661653 602E 4144 926E 9985B12FEC7E
TripleB
TripleB
20,784
181,493
Caryville, Tennessee
I know.... 🤣
You just need to upgrade to the i-4wd TL version.....problem solved
I wish there was something in between. But I’m getting more use to it, you gotta hammer down sometimes you might not necessarily want to and you cannot run one side only through a washout, but I am going mostly where I want to. With the Talon it’s weird because I’m always in 4wd where Pioneer I’d be in anything from turf-diff. It’s not the end of the world and wouldn’t have any other machine. Also no broken axles for either of us that had one.
SpeedBuggy
SpeedBuggy
1,289
10,214
WA
Hometeam
Hometeam
1,045
4,414
Normal, IL
I agree, the I-4wd has not stopped me from any climb or trail. But it has save a lot of broken axels on my rigs with how many different, unexperienced people I put in the driver's seat. My Talons have been like the town whore....everyone has had a turn! And they keep going!)
62,918
It’s the @TripleB of sxs!
TripleB
TripleB
20,784
181,493
I luv a good whore!
I have been winched a couple times where the Pioneers weren’t. And I will attribute at least some of the damage throughout the machine to being a little throttle heavy at times through tight stuff to get through. Slower speeds trying to be methodical it’s not as good and since you’re already in 4wd you’re stuck when you get stuck unlike diff where you click it in and reverse out.
Higher speeds less technical more open stuff it does very good, at times better, especially the faster you’re going. It does have positives as I’ve always said.
Almost 2900 this year has given me a pretty good feeL, oh and still officially nothing broken mechanically, that’s never happened on my 6 previous machines, so kudos to the Talon!
I added an inch in the front and 1.5” in the rear after the first ride (about 220 miles). Haven’t added any since and it’s been great. No rear sway bar
Man yours are way further down then mine. I know yours is R but mine are like 1/2 from top.
