Tigermark
Outside looking in.
You ham fisted goober , Your not supposed to use a 24’ crescent wrench on those little bolts.It never fails!!
So I had a little gear oil seep and figured I’d change the crush washers and change the diff fluid before a ride this weekend.. sure enough the damn drain bolt head twists off just as I’m starting to apply pressure to seat it. Luckily, the threads were good and I could put pressure on the head and got it to back out enough to get a set of needle nosed on it. Note to self.... when changing the diff fluid replace washers and bolts everytime! It’s worth the 5 dollars extra as now I have to run and hour up the road to get a drain bolt for a last minute fix! View attachment 90779
