Seems like you’re stalking her? That goes against probations, they won’t let you back out this time
If your tapping that you are the man !!! She is so skinny she'd half to run around in the shower to get wet . I'd put it in limp let it swell up here her bones crack !!
And that’s why you haven’t had sex in years... your standards are far too high for your appearance.It’s Darcizzle. She has a fishing show on YouTube. I’m not into fat chicks like y’all...
It’s like planning out what you’re going to do with your lotto winnings then hunting in your billfold for your last 5$ I do it all the time.And that’s why you haven’t had sex in years... your standards are far too high for your appearance.
We should’ve bought the blue!Drinking all of @joeymt33 supply!View attachment 90748
Wish I had room to bring it!We should’ve bought the blue!
Officially headed home tomorrow. Gonna take I-59 north through Mississippi towards Chattanooga. It’s about 14 hours total so i’ll Most likely be back sometime on Friday. I’m bringing back 20 lbs of pork and 16 lbs of crawfish boudin all packed and frozen in my Engel 12 volt freezer. That should last a little while. I may even freeze dry some of it after I get home. Mmmmmmmm.........I might even have some for the takeover in May.
Both of you look like wedge heads! HA!View attachment 90750 Lookee at the wee lad on the port side before ee became a pirate! For a time he could fly with them thar Dumbo ears!
No pictures but, @sugarray and I met up and had a couple beers last night. Was great to catch up. The boss and I crashed there family dinner!
Salad bowl haircutsBoth of you look like wedge heads! HA!
Damn dude that’s a bummer! I hate that last minute stuff you decide to do that goes to s***It never fails!!
So I had a little gear oil seep and figured I’d change the crush washers and change the diff fluid before a ride this weekend.. sure enough the damn drain bolt head twists off just as I’m starting to apply pressure to seat it. Luckily, the threads were good and I could put pressure on the head and got it to back out enough to get a set of needle nosed on it. Note to self.... when changing the diff fluid replace washers and bolts everytime! It’s worth the 5 dollars extra as now I have to run and hour up the road to get a drain bolt for a last minute fix! View attachment 90779
