320,459
And that’s why you haven’t had sex in years... your standards are far too high for your appearance.
It’s like planning out what you’re going to do with your lotto winnings then hunting in your billfold for your last 5$ I do it all the time.
BWAF
BWAF
I get paid to pass gas
8,857
42,437
Carthage MO
Cheers 7a6910fe96b66b88e09054ec39f079e3
103,736
Officially headed home tomorrow. Gonna take I-59 north through Mississippi towards Chattanooga. It’s about 14 hours total so i’ll Most likely be back sometime on Friday. I’m bringing back 20 lbs of pork and 16 lbs of crawfish boudin all packed and frozen in my Engel 12 volt freezer. That should last a little while. I may even freeze dry some of it after I get home. Mmmmmmmm.........I might even have some for the takeover in May.
103,736
FAD94FF5 41A7 4FC2 8A53 B5B8D4B10B68
Lookee at the wee lad on the port side before ee became a pirate! For a time he could fly with them thar Dumbo ears!
207,989
View attachment 90750 Lookee at the wee lad on the port side before ee became a pirate! For a time he could fly with them thar Dumbo ears!
Both of you look like wedge heads! HA!
It never fails!!
6AFFFE19 6F16 4AF9 894A 662C60DEC226
So I had a little gear oil seep and figured I’d change the crush washers and change the diff fluid before a ride this weekend.. sure enough the damn drain bolt head twists off just as I’m starting to apply pressure to seat it. Luckily, the threads were good and I could put pressure on the head and got it to back out enough to get a set of needle nosed on it. Note to self.... when changing the diff fluid replace washers and bolts everytime! It’s worth the 5 dollars extra as now I have to run and hour up the road to get a drain bolt for a last minute fix!
C8DBDD5A 9535 4A5E 8BF4 3F924EDD1B8F
320,459
It never fails!!
So I had a little gear oil seep and figured I’d change the crush washers and change the diff fluid before a ride this weekend.. sure enough the damn drain bolt head twists off just as I’m starting to apply pressure to seat it. Luckily, the threads were good and I could put pressure on the head and got it to back out enough to get a set of needle nosed on it. Note to self.... when changing the diff fluid replace washers and bolts everytime! It’s worth the 5 dollars extra as now I have to run and hour up the road to get a drain bolt for a last minute fix! View attachment 90779
Damn dude that’s a bummer! I hate that last minute stuff you decide to do that goes to s***
