A47144FE B4AE 4C40 9909 A192E0F7EB6B
Look at this little beauty!
74E697C6 43EB 4EEE 96A5 B7C3604AD7FE
Went to change the oil on the wife’s Yukon for the first time and was pleasantly surprised to find this setup! Best setup I’ve ever seen... they should all be this easy!
Buuuuut that engineering common sense was lost on the head lights. The whole headlight assembly must be removed to replace any of the bulbs. And it doesn’t just slip out either. I was an hour plus just to swap to two LED head light bulbs!
13,351
64,949
If you are going to continue to service the truck yourself. Grab a fumoto valve for the drain. No tools required to change the oil except a filter wrench.
41,751
They get rid of the pin setup they used for years on the headlights?
GM generally keeps things pretty simple, but occasionally they really throw a turd in the pool. 1st Gen Colorado's come to mind.
